secondary ip address - processed switched?
Apr 1st, 2008
Hi all,
I am seeing quite a high percentage (30%) of my packets being processed switched on a 2611 router. CEF is enabled on all interfaces.
Would like to confirm if packets directed to a "secondary" ip address will be processed switched.
As a temporary solution, my router serves an additional subnet with the ip address <address> <netmask> secondary command - could this be what's causing the high percentage of process switched packets?
evsrajatgupta Tue, 04/01/2008 - 06:27
Hi bangkydotnet,
Is a temporary solution during Ip migration and it do have a adverse effect on the router performance.
bangkydotnet Tue, 04/01/2008 - 06:30
Hi. Indeed, this is just a temporary solution. And yes, it has a somewhat adverse effect in the sense that CPU utilization is higher than usual (though not dangerously high).
However, can it be confirmed that such packets will be process switched?
