UNKNOWN_ERROR in CCM 4.0(2a) SR1
Apr 1st, 2008
I am getting a series of UNKNOWN_ERROR's:
Error: UNKNOWN_ALARM:kConfigParaNotFound
ParaNameInfo: BackupCallManagerName ( read by CMyProcessConfigList::GetSafeStringParam() ) not found in DB, using default value of
ParaNameInfo: CallManagerName ( read by CMyProcessConfigList::GetSafeStringParam() ) not found in DB, using default value of NO_SUCH_NAME
ParaNameInfo: MwiCallingSearchSpace ( read by CMyProcessConfigList::GetSafeGuidParam() ) not found in DB, using default value of
In addition, we CAN NOT do a CFWDALL, and if a phone had call forward on prior to this error and try to remove it, we get the message "DATABASE ERROR" on the 7940 phone.
Rob Huffman Tue, 04/01/2008 - 06:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rob,
Sounds like a Replication issue :( If the Pub is down or Replication between the Pub and Subs is broken no changes can be made to CFWD ALL. Here is a doc that speaks to this question;
This is a list of possible symptoms if the subscriber stops replicating from the publisher:
Changes that are made on the publisher are not reflected on phones that are registered with the subscriber.
Outbound calls fail on phones registered with the subscriber. As soon as you dial 9 you hear a re-order tone.
Call Forward All (CFwdALL) does not work.
IP phone displays Error Database.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
And this good doc;
Cisco CallManager Issues with Call Forward All
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801b3f4b.shtml
Hope this helps!
Rob
