cme and g711ulaw codec
Apr 1st, 2008
I have a cme connected to a PBX over a wan using voip. Works fine if dial-peer voice xxx voip used codec g729 by default. If I code g711ulaw, I get fast busy. Trying to understand why this would be so. The sip peer for vm cue has codec g711ulaw no problem. If I remove the codec g711ulaw from the voip peer it works again. thoughts and thanks
paolo bevilacqua Tue, 04/01/2008 - 06:40
  • Hall of Fame,
    Founding Member
That is the remote PBX that wants G.729 only.
What problems does it cause to you ?
whanson Tue, 04/01/2008 - 07:42
not following your answer. PBX is connected via t1. TDM at that point. What does g711 or g729 got to do with it?
paolo bevilacqua Tue, 04/01/2008 - 07:45
  • Hall of Fame,
    Founding Member
Ok, then you need g711u on the DPs on both systems doing VoIP. You mentioned one only.
