UC520 CCME CUE transfer to VM
Apr 1st, 2008
How do I configure CUE/CCME to transfer directly to a user mailbox?
If the operator answers and does not want to transfer to user just to mailbox?
Andy
paolo bevilacqua Tue, 04/01/2008 - 08:18
  • Hall of Fame,
    Founding Member
One way is with the monitor or shared lines to the operator. This way, operator answers from the shared line or transfers to it.
The when transferring again to CUE, the call would go directly to the right mailbox.
Kenneth Mohammed Tue, 04/01/2008 - 08:21
  • Silver, 250 points or more
Ok...here is an example:
1. Make an ephone-dn
ephone-dn 49
number 8....
description ***Express Messaging***
call-forward all [VM Pilot]
2. Then in the CUE, you need to make the E164 phone numbers with the same preceding digit (8 in this case)in front of the extension..example:
username user1 phonenumbere164 81001
so when the receptionist wants to send a caller directly to voicemail, she will transfer the call to 8.... (4 digit extension)
Hope this helps..I know its not the clearest explanation, but it should work.
Rob Huffman Tue, 04/01/2008 - 08:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Andy,
Just to add a note to the good thought from Paolo. Here is another method, the steps required are nicely detailed in this good Tech Note;
Transfer a Caller Directly into a Unity Express Mailbox
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979.shtml#cue_int_ccm_exp
Hope this helps!
Rob
