Problems with CCMUSER access
Apr 1st, 2008
All CCM 5.1 end users are unable to enter to their CCMuser web page. It asks for a username and password, but after entering this information, the system shows a "permission denied" message.
All users belong to a group where I have included a role similar to "Standard CCMUSER Administration". (Same rights)
Anyone does have an idea why it is failing to enter? Thanks in advance
Overall Rating: 4 (2 ratings)
Jaime Valencia Tue, 04/01/2008 - 09:15
  • Cisco Employee,
  • Hall of Fame,
    2011
OK, so the users are not really in the Std CCMUser Admin group? but in a group you created with 'similar' permissions?
if you add one test user to the original Standard CCMUSER Administration does it work?
if it does then u need to check all the roles of the other group to match.
javalenc
if this helps, please rate
dsalamanca Wed, 04/02/2008 - 01:40
Ok, the problem has been solved.
The problem was that I added the users to the "Standard CCMUSER Administration" group but not to the "Standard CCM End Users" group.
Thanks for your help.
