dsfarm configuration help
Apr 1st, 2008
sccp local GigabitEthernet0/1.20
sccp ccm 172.28.80.10 identifier 1 version 4.1
sccp ccm 172.28.80.11 identifier 2 version 4.1
sccp
sccp ccm group 10
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 10 register TRSBZV-01
associate profile 30 register MTPBZV-01
associate profile 20 register CFBBZV-01
switchover method immediate
switchback method immediate
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 8
associate application SCCP
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dspfarm profile 30 mtp
codec g711ulaw
maximum sessions hardware 3
maximum sessions software 3
I have this configuration on s cisco 2821 relating to Codecs.Not having much voice knoweledge i am unable to understand this configuration. Furthermore, i also want to configure the same on another cisco 2811 for some other remote site.
Any link / resource will be highly appreciated...
matthewpage Tue, 04/01/2008 - 10:06
  • Bronze, 100 points or more
So you arent having any problems with the configuration you just want to know what it does? If so then have a read of this guide
it covers the configuration you have. Its pretty long and detailed but it should help you out with your configuration.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
Just to add you are missing some commands at the top relating to the voice card. This needs to be configured as well before it will work
conf t
voice-card slotx/x
dsp services dspfarm
If you have any questions then please feel free to reply back.
Matt
munawar.zeeshan Tue, 04/01/2008 - 10:57
Yes, it is very hepful link.
Can somebody further enhance the explanation for transcoding and conferencing, so i may develop some basic level understanding.Like y they are used etc etc
