Fax over IP... confused!
olivier.bedard
Hi guys,
I'm very confused about how fax relay works in a Cisco VoIP environment. I've read all the documents I could find, but questions remains.
Do I have to apply the directives on a dial-peer with the destination-pattern set as the fax extension number ?
Or does the system automatically detects if the call is a voice call or a fax call ?
In fact, I don't quite understand how I can define what devices should use fax relay (cisco protocol, not t38)
Here's an example of what I've done so far.
37002 is the extension number of a fax in a remote office.
dial-peer voice 37002 voip
destination-pattern 37002
fax-relay ecm disable
fax-relay sg3-to-g3
fax protocol cisco
Is that right ?
Thanks !
you may want to add the ip address of the remote gateway you are sending to under the dial-peer
session target ipv4: [ip address of remote gateway]
leonardolopes
Level 5
Level 5
The dial-peer not detected which device delivery the call
You have insert the destination for each device
for example:
dial-peer voice 1234 voip
destination-pattern 1234
session target ipv4: 192.168.1.1
or
dial-peer voice 1234 pots
voice-port 0/0/0
do you understand?
