Upgrading Catalyst 4006 to 4506, i.e. Sup IV
Answered Question
Can you load a 12.4 version of the IOS onto a 4006 chassis that has been upgraded from a Sup II to a Sup IV? 4006 has come to the EOS and it looked like the option was to upgrade to a 4506 IOS.
Correct Answer by Edison Ortiz about 9 years 3 months ago
There is only one explanation for that. It seems you weren't typing the filename from the image correctly on the boot system command.
The image may contain "_" or a "-" that you may have missed. What I usually do, is dir bootflash: and copy the image name as displayed in the CLI onto the command.
I never trust myself on typing the image name correctly :)
I haven't seen a 4006 in years :)
4006 is current EOL so it's very hard to find any documentation on it but I 'assume' the Sup should load the installed IOS.
I don't have any hardware to duplicate your environment, sorry..
Overall Rating: 5 (5 ratings)
Edison Ortiz Tue, 04/01/2008 - 15:21
  • Hall of Fame,
    Founding Member
Yes, the image runs on the Sup. The Sup you have would be the same Sup running on a 4506, therefore there is no difference.
Good luck!
__
Edison.
Correct Answer
Edison Ortiz Tue, 04/01/2008 - 19:12
  • Hall of Fame,
    Founding Member
Actually, it's not strange at all. Cisco renamed the Cat 4K images to "cat4500" from "cat4000" starting with 12.2.(25)SG4. cat4000-i9s-mz.122-25.EWA11.bin is in fact a 4500 IOS image. You need to make sure that the boot parameter was properly set and that the new image was specified first in the list. Post back a "sh bootvar"
Edison Ortiz Tue, 04/01/2008 - 19:43
  • Hall of Fame,
    Founding Member
I did some digging and found the 4006 chassis is supported up to 12.2(37)SG release code, per the Release Notes:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.html
This URL should help troubleshooting your issue
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a008011e6b4.shtml
HTH,
__
Edison.
Once again -- you guys are INCREDIBLE! You are correct about the support for the 4006 chasis quitting at the 12.2(37)SG code: From your first link (quote below):
"Note The Catalyst 4006 chassis is no longer supported in Cisco IOS Release 12.2(37)SG." This explains much.
cat4500-ipbasek9-mz.122-31.SGA5.bin should work and was last updated 11-FEB-2008. It appears to have current support.
I guess next time I will look at the "release note" for the 4500 switch itself.
The second link you provided shows that I could have used the Sup V blade in the 4006 chassis, with the caveat that I could only upgrade to images before the 12.2(37)SG image (when new hardware support showed up in the train).
Incredible responces. Thank you very very much! I will let you know how it goes.
Correct Answer
Edison Ortiz Wed, 04/02/2008 - 17:23
  • Hall of Fame,
    Founding Member
