Block incoming call
Apr 1st, 2008
Hy guys,
I have a doubt
it is possible to block an extension to receive incoming calls of PSTN using CSS and Partition or other feature?
Overall Rating: 5 (2 ratings)
Kenneth Mohammed Tue, 04/01/2008 - 13:46
That all depends. Are you trying to block a call based on the calling number, or are you trying to block all PSTN calls to this extension? Is this an MGCP or H.323 gateway. Please provide more information. Thanks
leonardolopes Tue, 04/01/2008 - 13:52
Hi kenneth,
I need to block any incoming call of PSTN for some extensions, however it would not like to use translations for that, Gateway uses H323
Do you have any ideia?
leonardolopes Tue, 04/01/2008 - 14:19
but it is that that would not like to use because I have many numbers that cannot receive external calls, and the translation-rule it is limited to 15 numbers by each translation
in this case I would have to create several translations-rules hindering the administration
but thank you for the help.
