ACS 1113 hyperterminal problems
Apr 1st, 2008
folks
i have a ACS 1113 appliance which i'm trying to hyperterminal to but with no joy
i'm using
115200
8
N
No flow control
but i can't get anything from the console
i have tried the same on my backup box but still the same
does anyone know the actual settings
thanks to anyone taking the time to reply
Overall Rating: 5 (1 ratings)
smalkeric Mon, 04/07/2008 - 10:54
  • Silver, 250 points or more
change the console cables. also give the proper console parameter for the console session with the box
mulhollandm Mon, 04/07/2008 - 11:44
i resolved the the problem along the lines of your suggestion
i use both juniper and cisco kit but i had got the db9 plugs mixed up
when i made sure the console cable had a db9 from the acs1113 box it all worked
must have been an issue with pin outs
many thanks for taking the time to reply
