Will this work?
cventicinque
I have a 1100 series AP on my LAN. I have a 2511 access server on the other side of my house that is isolated from my LAN. I want to connect the 2511's ethernet port to a 350 AP in hopes that I can now access the 2511 from my LAN.
I am guessing that if I configure the same SSID and Encrytion along with IPs that are valid on my LAN subnet that it will work.
Am I wrong?
Thank you!
This should help. You need a WGB or a wireless bridge that connects to a hub/switch.
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_configuration_example09186a00805b9b87.shtml#configure2
-Scott
7 Replies 7
Scott Fella
It should.... I used a wireless bridge to connect to my lab that I stuck in a closet:)
-Scott
Thank you very much.
Can anyone else please confirm if this will work.
I appreciate it!
-Scott
This is almost exactly what I need...
http://www.cisco.com/warp/public/102/ap_as_wgb1.gif
Only difference is that my Root Access Point is an 1100 and my WGB is a 350. In that diagram both WAPs are 1240s. Does anyone know if my devices offer this functionality?
Thank you VERY MUCH!
I found this but, what is the difference between an access point, a wireless bridge and a workgroup bridge?
It doesn't matter what AP you have, it matters if the WGB does what you want it to do. If your 350 is a WGB, then you are in luck....
-Scott
It looks like I will have to do some role reversal for my APs per this info:
http://www.cisco.com/en/US/products/hw/wireless/ps441/products_qanda_item09186a0080094644.shtml#q21
Q. What Autonomous IOS APs can act as a WGB?
A. The AP1100, AP1130, AP200, AP1240, and BR1310 all support WGB mode of operation. The AP350 and the BR1400 do not support WGB.
Sort of a bummer that I will have to downgrade my LAN from 54M to 11M but, I guess I can deal with it until I find a cheap 1100.
Thanks again!
