rebooting all 7941s
Answered Question
Apr 1st, 2008
Hi experts,
Is there a way to reboot thru Call Manager or other to reboot only those 7941 phones? We just upgraded the firmware.
Tnx
Correct Answer by Rob Huffman about 9 years 3 months ago
Hi Robert,
Sure, via ccmadmin if you go to Device>Phone>Search by Device Type>7941 and all the 7941's will be available (check 50 per page). Then Select-All checkbox and reset. You just go page by page and reset all 50.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 04/01/2008 - 17:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Robert,
Hope this helps!
Rob
Eric Krieger Wed, 04/02/2008 - 00:39
In addition to the solution Rob gave you, you might want to use BAT if you want to reboot an hugh amount of Phones (Update Phones -> search by Device Type -> select "reset phones" -> press update).
Remember though that the Communications Manager (CallManager) throttles the number of TFTP requests to control/reduce the load.
Eric
