WAAS - Error Message "Aggregation error" Showing up in SYSLOG
Answered Question
I am seeing the following message show up on my syslog for my WAAS device "tcpproxy: (111872) conn-id: 2021463: RE Aggregation error: process_full_tree failed -1105 (Read failed: not found) " This is not showing up on the logs on the WAAS itself. Is this "normal" stuff?
Thanks for your help.
Correct Answer by pknoops about 9 years 1 month ago
This error means that the chunk was saved to some sig block but can not be read from it. It could be because something happened to the cache, for example sig blocks were
overwritten (FIFO). If the aggregation errors are few or occasional, these
errors should not impact performance.
Pete..
Overall Rating: 5 (1 ratings)
Correct Answer
pknoops Wed, 04/02/2008 - 08:57
  • Bronze, 100 points or more
Pete..
