ISDN PRI to BRI converter
Apr 2nd, 2008
We have ISDN PRI connected to a Cisco 2851 router and using it for voice. Is it possible to take few BRI connections using some kind of converter (module) installed on the router??
I heard some vendor like Nortel have this kind of converter...
Can someone give your input...
Vijay
Overall Rating: 2.8 (3 ratings)
Goutam Sanyal Wed, 04/02/2008 - 05:30
Hi Vijayakumar Raghupathi, You can separate the PRI Channels as per your requirement. I mean you can use 20 channels for voice and rest of for other purpose, but do not know any device like converter / module that can separate the channel/s. Thanks Goutam.
rv_viji Fri, 04/04/2008 - 01:18
Thanks for the excellent information, this is what I was really looking for...
Vijay
