1801 with two internet connection
yaniv
I need to configure 1801 with the following requirement:
1. one link to isp1 with adsl line
2. one link to isp2 with cable line
3. to cut the lan ports to few vlans
4. to route each vlan via different isp
5. to make QoS to keep amount of bandwidth to video application
6. I don't need BGP cause its doesn't do load balance
Do you think it's possible?
Do you think it will handle it?
Hi yaniv,
First of all, It's possible.
As per your requirement,I would think about Policy-Base routing to help you out.
Just let some vlans to go ISP_1 and others to go ISP_2.One thing I would very carefully think about NAT as well when you want to do this.
Hi poalo , Seems you are in a rush to get a fantastic star!! 5 points from mind.
Hopes this helps
Thot
7 Replies 7
paolo bevilacqua
Yes, it's possible:
Note for 6, BGP does load-balancing. The real issue is that is complicated and expensive to obtain, setup, and maintain.
Thanks a lot
You're welcome. Please remember to rate useful posts with the scrollbox below!
Hi yaniv,
Hopes this helps
Thot
Hi again,
I did some work
I hope I am not a trouble but I need to here your advise
Thanks again
Hi again,
I did some work
Thanks again
Hi, I haven't checked the full config, seems to me you're in the right direction, I would use two separate ACL for the source IPs, and in the route-map no match for interface, rather use "set default".
