Backup WebVPN personalization on ASA
Hi all,
I'm looking for a system to backup the configuration of the ASA like this I've noticed:
if the ASA is 5510 or higher and has sw 8.x and ASDM 6.x we have ASDM -> Tools -> Backup Configuration command that create a folder containing all configuration files and webvpn personalization
What I have to do to have the same command on ASA 5505 sw 8.x and ASDM 6.x? Or is there someting similar using the console too?
And what else for ASA which have sw 7.x and ASDM 5.x, is there the possibility to backup webvpn personalization?
Thanks a lot,
btfreitag Sat, 04/23/2011 - 18:50
I know this hasn't been answered in quite a while... but is there a solution for this?
Jitendra Siyag Mon, 04/25/2011 - 00:59
i am not sure in ASDM but we can do this using CLI. below are the commands
export webvpn Anyconnect-customization name url
export webvpn customization name url
below is the command reference document for the commands:
Plus, you can also look in the below document for Smart Call Home:
