04-02-2008 02:52 AM - edited 03-05-2019 10:07 PM
I know this has been discussed in detail before but any advice would be much appreciated!
We have a 6509 with SUP2's an SFM2 and multiple WS-X6548-GE-TX's, I understand that this
card is oversubscribed to an 8:1 ratio, whereby if one port is pushing a gig then the
other 7 will have to fight for contention. My question is this: With the SFM2 module
increasing the backplane capacity to 256gigs is the ratio still 8:1 for the WS-X6548-GE-TX modules?
Or can each port theoretically supply 1 gig to each host at the same time continuously?
Solved! Go to Solution.
04-02-2008 02:59 AM
Without an SFM the 6548 will have to share the 32Gbps classic bus.
With an SFM it gets a dedicated 8Gbps connection to the switfch fabric. This means that there is still a lot of contention with this blade.
So in short with an SFM you still have a contended blade which is why Cisco recommend this as a wiring closet blade and not a server blade. Of course if you have clients that need a dedicated Gbp each then it's not much good in the wiring closet either.
Jon
04-02-2008 02:59 AM
Jon
04-02-2008 03:13 AM
Appreciate the quick response and help Jon, kinda knew that thats were we were heading..
