QoS using 802.1q user_priority bits
Apr 2nd, 2008
I would like to know how to configure QoS in a layer 2 network using the user priority bits in the 802.1q VLAN tag. Any comments or document references would be great.
Jon Marshall Wed, 04/02/2008 - 04:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
That's quite open ended. Which type of switches are you talking about. Basically it's called CoS (Class of Service) and you have values 0 - 7 to work with.
CoS on catalyst switches is very switch dependant. If you let us the know the type of switches involved we can point you to some docs.
Jon
