JTAPI client version inconsistent
Apr 2nd, 2008
HI Guys
I have done an installation of UCCX5.0(2)with ccm 5.1.1. I get the following error when i log in as the crs admin;
"The cisco JTAPI Client versions are inconsisten. Please go to cisco JTAPI Resync to install the JTAPI client"
I do that an i get another error saying to resync.
Any one had the some problem and any ideas on how to fix this??
Matt
Overall Rating: 4.5 (2 ratings)
kthorngr Wed, 04/02/2008 - 17:15
Maybe you are running into CSCsk19938. Have you tried to download and install the JTAPI plugin from CUCM?
Kevin
eric.spagna Thu, 04/03/2008 - 00:54
I am going to agree with kthorngr on this one.
Go to the CM Admin Page
Select "Application --> Install Plug-ins"
Scroll down and install the Cisco JTAPI client.
Hope that helps.. thanks
matthewpage Thu, 04/03/2008 - 09:33
Yeah i actually thought the problem would be that the jtapi version on the UCCX would be newer than the ccm version. So i deleleted the uccx version and tried downloading the jtapi client from ccm and i still got the same error. Any other ideas? What sort of issue would this error cause me?
Thanks guys
Matt
f.gouger Wed, 05/07/2008 - 09:28
I was running into the same problem and I just want to inform you what I did but I am sure you did it before my post.
I have two IPCC 5.0.2 with CCM 6.1 and I had the same error as you. I did install JTAPI from the CCM but I still got the error message.
I decide to reboot both IPCC servers, after the reboot I was still having the error message but I try a resync and it works.
Hope this will help you.
szawdzin Mon, 08/11/2008 - 00:08
Did You find any solution/workaround?
I have same problem with new installation: UCCX5.02 with UCCM6.1.2
javiero_2 Thu, 08/21/2008 - 15:04
There seems to be a bug. You can resolve the issue by copying the three .jar files in the c:\windows\java\lib folder to c:\winnt\java\lib .
You can find the error by looking at your MADM logs. Search for JTAPIClientInstallException . It references this bad directory. Normally, you would not have a c:\WINNT folder on this OS.
By the way, did you happen to install this from the non-Cisco 2003 OS Media?
Please rate if this helps you out. Thanks
Javier Oropesa
Eventus Group
szawdzin Thu, 08/21/2008 - 22:13
something was wrong with OS.
I reinstalled system and now is OK.
Thanks for your help.
