WLAN Cisco 4404
Apr 2nd, 2008
I have a question about your WLAN Cisco 4404. I have a plan with 62 AP AIR-AP1242AG
Lightweight version (LWAPP). The AP will be distributed on three levels with two
technicals offices. I want to install two POE switch per level connected with the AP and
the switch connected in the WLAN controler. Finnaly i have six switchs, two per level and
these swiths will be connected in the WLAN controler. Is it possible ?
ericgarnel Wed, 04/02/2008 - 08:54
Yes - assuming that the switches will be in the same vtp domain. The switch ports (access mode) that the APs connect to will need to be in the same vlan as the management & ap-management ports and the switch ports that the controller connects to need to be in dot1q trunking mode.
Here is a good start
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
