Unity diag log settings
Apr 2nd, 2008
Unity 4.2:
When I gather specific logs eg: AvCsMgr, it is only showing me the logs from todays's date.
I've set the max log size to 1 gig and there is only 300M in the logs folder.
Is there a way to get logs previous to the day you check?
Ginger Dillon Wed, 04/02/2008 - 15:15
Hi Scott -
In the Gather Logs wizard, try selecting the 3rd radial button "Process logs over specified time frame". Press Next. In the Start Time field, click on the Month and then select the up or down arrow; then select the day and change by using the up or down arrow. Make sure you adjust the Duration (Hours) accordingly. In this instance, I would recommend unchecking the Include fields for the application and system event log. Then select Next. Once these process, you can select the Open Logs in Viewer button and it opens automatically - pretty cool :-)
