Traceroute through Pix501 still not working...
Apr 2nd, 2008
I've got a pix 501 and I've permitted ALL icmp through the outside and inside access-lists, yet traceroute through this firewall still does not work, it just shows stars for all hops past the pix until the actual final destination. I've read a ton of info on this and everyone just says to allow ICMP time-exceeded and echo-reply which my permit icmp any any should cover, right? Anything else I should check? Thanks
Jason
abinjola Wed, 04/02/2008 - 07:30
  • Cisco Employee,
on the outside access-list if you are permitting icmp any any then it covers all the icmp types
are you sure the upstream router not blocking any icmp type ?
does it work bypassing the pix ?
jasonhumes Wed, 04/02/2008 - 07:45
Great, thanks very much! It turns out one of our admins had blocked the icmp time-exceeded msg from the router between myself and the pix...so the pix was fine, but the router was breaking traceroute. Thanks!
Jason
