Apr 2nd, 2008
We have one Client wished to run MPLS VPN. His head office is connected to our ISP Backbone via a leased line, all other branches are connected via ADSL. The IP addresses are assigned to the DSL when the user connects and the DSL gets a virtual interface on the PE when it connects
Whether MPLS VPN is possible with this dynamically created Virtual interface and Head office?
Overall Rating: 5 (2 ratings)
mirco.orlandi Wed, 04/02/2008 - 11:27
I don't know if you are using ppp with radius authentications over DSL connections. If you are in this scenario, you can put a Virtual-access into a vrf using Cisco-AVPair in radius cfg.
This is an example of radius user definition:
Auth-Type = Local, User-Password =
Cisco-AVPair += "lcp:send-secret=",
Cisco-AVPair += "lcp:interface-config#1=ip vrf forwarding ",
Cisco-AVPair += "lcp:interface-config#2=ip address"
Based on "username", a Virtual-access is dynamically assigned to a vrf.
If you are not using IGP from PE to CE (over DSL link), you can also use radius to install a static route.
Hope this helps.
mohammedmahmoud Wed, 04/02/2008 - 14:36
Agree with Micro, and further if you have issues with using Cisco-AVPair, you can apply the VRF under the virtual-template itself whether it is PPPoA or PPPoE.
Mohammed Mahmoud.
Haris P Fri, 04/04/2008 - 23:19
Dear Mahmoud ,
In any case I think we need to be depending on Cisco AVPair , But I'm using a third party radius software which doesn't support AVPair . I'm little bit confused about about how I can do a vrf under virtual-template without depending on Radius .
mohammedmahmoud Sat, 04/05/2008 - 02:57
Hi Haris,
It can be done by simply applying the "ip vrf forwarding x" command under the virtual-template interface itself, then when the virtual-access is cloned it will inherit the VRF under the virtual-template.
Mohammed Mahmoud.
