VPN client behind PIX
molebrian
I have a problem with a vpn client sitting inside a PIX 525 7.2(2). I can connect to the destination concentrator but cannot ping any resources (tested and works fine through little ADSL SOHO kit). After searching here, I added isakmp nat-traversal 20 to the config plus a NAT exemption. I now see clean UDP and TCP traffic in the syslog for this host but I still no replies.....Any help much appreciated as I'm losing hair on this one......
"The key here is to look at the configuration
on the VPN concentrator. You need to setup
NAT-T on the VPN concentrator, as follow:
Configuration | Tunneling and Security | IPSec | NAT Transparency
There is a check box for "IPSec over NAT-T".
Check that box and it will work.
Thats correct. I understood just the opposite at my first fast look at the question, thats why I rejected to not to NAT-T at PIX side.
"Cisco VPN client does not use PPTP protocol"
Thats correct too, but I didnt see any statement about Cisco VPN client, thats why I suggested it. But if I recall correct, client shouldnt have been able to establish connection if it was a PPTP client, without the fixup protocol I mention. So most probably it is Cisco VPN client.
Setting NAT-T at concentrator will resolve the issue as you mentioned.
Brian, if still no joy after setting NAT-T in concentrator, we need the config of concentrator.
9 Replies 9
husycisco
Level 7
Level 7
Hi Brian,
Please attach your sanitized config
husycisco
Level 7
Level 7
Hi Brian,
You need to enable NAT-T on the VPN concentrator. You do not need NAT-T on
the Pix.
Edited... Misunderstood the issue
It is working for me as we speak.
You are right m8, I misunderstood the issue :)
Brian, issue the following command in PIX config
fixup protocol pptp 1723
Cisco VPN client does not use PPTP protocol.
I do not think you need that.
Thanks folks, I've asked the other side but there is change control to get through before I can test.......I'll keep this updated.
