MWI on 7912 phones
Apr 2nd, 2008
We use CCM 6.0.1 and UC 2.0.1
I recently changed the DN's for the IP Phones in CCM. Two of the 7912's we have in CCM do not light the handset when a message is left. Since I did not make any changes to the devices other than changing the DN what might cause this. I did reset the Device. Do I need to Reset the DN as well?
Brandon Buffin Wed, 04/02/2008 - 08:21
  • Purple, 4500 points or more
Did you change the parition associated with the DNs? Can you dial the MWI on/off numbers from the phone and turn the light on/off?
Brandon
Mojo1 Wed, 04/02/2008 - 08:24
The partition has not changed.
How do you do dial the MWI on/off numbers from the phone so I can verify?
Brandon Buffin Wed, 04/02/2008 - 08:37
Find your MWI on/off numbers either in UC or CUCM and dial them from the phone. Dialing the on number should turn the light on. Dialing the off number should turn the light off.
Brandon
mattcalderon Wed, 04/02/2008 - 08:26
  • Silver, 250 points or more
You said you changed the DNs in call manager, but did you look at UC and change the DNs there? When a message is being left for the old DN how do the new ones know to turn on MWI?
Mojo1 Wed, 04/02/2008 - 08:31
Yes I changed the numbers in UC as well since I had to Synch the users so they would nor lose their greetings.
I did the same procedure to alot of other users and have not had a problem with their phones.
mattcalderon Wed, 04/02/2008 - 08:51
Have you taken brandon's suggestion and dial the MWI ON/OFF DNs?
Mojo1 Wed, 04/02/2008 - 08:59
How do you dial the MWI ON/OFF DN's ?
All I did just now was go into UC and go to Telephony Integrations - Phone System-Click the Run Button for Synchronize All MWIs on This Phone System.
I have never used a key stroke on a phone to turn the MWI on or off. What would that be please?
Brandon Buffin Wed, 04/02/2008 - 09:01
You can just dial the MWI on/off numbers like calling any other DN.
Brandon
mattcalderon Wed, 04/02/2008 - 09:37
Look at your VM configurations in call manager and look for MWI on/off. Then dial the extenstions associated with the on/off for MWI.
Mojo1 Wed, 04/02/2008 - 10:17
3333 is MWI/On
3334 is MWI/Off
I had the user dial 3333 and when I left a message the light did not come on.
Brandon Buffin Wed, 04/02/2008 - 10:19
You should not have to leave a message. The light should come on immediately after dialing 3333. So, this was working previously for this phone? No change in partition or calling search space?
Brandon
Mojo1 Wed, 04/02/2008 - 10:22
Yes it was working prior to changing the DN in CCM. Do I need to delete the user in Unity Connection or in Call Manager or both and add them back?
