blocking snmp v1 & 2c but allow snmp version 3 on ASA
Apr 2nd, 2008
I have a customer, due to cost saving, recently migrated from
a checkpoint NGx firewall over to Cisco ASA 5510
firewall with 8.0(3).
There is a Linux host on the internal network that supports
snmp version 1, 2c and 3. I want host Linux_internal to querry
host SNMP_Server with snmp version 1 or 2c; however, Linux_vendors
has to use snmp version 3 to querry the SNMP_Server host because
they are going across the Internet and that I want the snmp
traffic to be encrypted.
I want to know how it can be done with ASA5510. Prior to the
migration over to the ASA5510, I used Checkpoint firewall
integrated SmartDefense to make this work.
Is it possible with ASA to block access snmp version 1 and 2c
over the Internet and allow only snmp version 3?
Thanks.
pengfang Thu, 04/03/2008 - 12:02
Yes,you can do this by "SNMP Inspection". The software later than 7.01 can support the feature,I wrote an example as followed:
access-list snmp-acl permit udp any any eq 161
access-list snmp-acl permit udp any any eq 162
class-map snmp-port
--> match access-list snmp-acl
snmp-map inbound_snmp
--> deny version 1
--> deny version 2
policy-map inbound_policy
--> class snmp-port
------> inspect snmp inbound_snmp
service-policy inbound_policy interface outside
Verify:
show service-policy inspect snmp
Of course you can use default "global_policy" which applies to all interfaces.
Hope it helps.
cisco24x7 Fri, 04/04/2008 - 05:52
thanks. I will give it a try today.
One more question. Can ASA have the ability
to block ssh verison 1 through, NOT to, the
firewall with the same scenario?
pengfang Fri, 04/04/2008 - 09:51
I don't think you can do that.ASA only supports very limited Application Layer Protocol Inspection, SSH is not in the list.
