Help with VPN tunnel with CheckPoint (from ASA 7.2(3))
Apr 2nd, 2008
I have a VPN tunnel with a Checkpoint, and because of the CheckPoint's unfortunate behavior of supernetting, I've had to use supernets in the crypto map on the ASA. All was well until I decided to modify a setting on CheckPoint to prevent supernetting (ike_use_largest_possible_subnets changed from "true" to "false"). I updated the crypto map and did "clear crypto isakmp sa" and "clear crypto ipsec sa" but I could not get the tunnel to work correctly and had to fall back.
Have any of you been through this and if so, can you share your experience, advice, wisdom, etc.? I do not do much VPN work on the Cisco ASAs so maybe I didn't clear everything properly or didn't do the commands in the right order, or something?
I did not reload the Cisco. Maybe that's what I needed to do???
I did fall back on both the CheckPoint and ASA and the tunnel is up and working, but I see a lot of "duplicate phase 2 packet" messages on the ASA, and on the checkpoint I see a phase 2 packet with the supernet (x.x.x.0/23) then a delete, then another phase 2 packet with the x.x.x.0/24, so I still don't think things are working correctly.
I also tried "debug crypto isakmp" and "debug crypto ipsec" but I don't see any output. I am doing ssh to the Cisco ASA. Where does the output go? Sorry if that's a really stupid question. I did search the forum and Cisco's doc but didn't find anything.
Thanks in advance for any help you can provide.
Chris.
cisco24x7 Wed, 04/02/2008 - 09:24
  • Silver, 250 points or more
Please provide the following information:
On Checkpoint, provide the following:
-uname -a
-fw ver
-Are you using traditional mode for simplified
mode?
a couple of comments:
1- you do not need to reload the ASA. This
is an appliance, not microsoft windows. On
the other hand, you're dealing with ED code
on the ASA. There are known issue with ED
code,
2- Unless you have special reasons to use
traditional mode, use simplified mode because
in NGx simplified mode, you have the ability
to make it negotiate with "hosts". Yes, it
will not be efficient but it will work.
However, this option is only available in
Checkpoint VPN Simplified mode. Furthermore,
if you're using Checkpoint traditional mode,
there are a lot of restrictions to this
method.
3- if you have to use traditional mode, you
can edit the $FWDIR/lib/user.def file and
put in the network in there. I do not like
this but this is the way to do it in
Checkpoint NG Feature Pack 3 and NG with
Application Intelligence R55. In NGx, you do
not need it in simplified mode, but you need
to do this in traditional mode. That being
said, I stop using traditional mode after
checkpoint 4.1 so you have to try it and
see it for yourself.
4- On the ASA, the configuration is very
simple.
5- Change everything to checkpoint VPN
simplified mode and it will work for you.
This is a very simple configuration.
CCIE Security
calterio Wed, 04/02/2008 - 09:46
Thanks for replying. We're running R62 (no hfa) with traditional mode. We have over 40 vpn tunnels so it is not an option to just convert to simplified mode. This is a plan but not something I can do immediately to solve this issue.
When ike_use_largest_possible_subnet didn't work, I did try modifying user.def but that also did not work. The var has suggested coding the inoperable device properties to "one tunnel per pair of hosts", which can be done even in traditional mode but does not seem to work (tried it before) so maybe that's your point about trad mode having restrictions.
I have a thread open on the CheckPoint forum on this, but I'm just trying to determine if, on the ASA side, I've done something incorrectly, as I'm not as familiar with VPNs on that device.
I have read about issues with Cisco where a reload seems to resolve issues with the SA after changes are made, and in fact, the changes I made caused issues with another Cisco device (1841) we have a tunnel with (that I don't manage) and the admin for that device had to reset the device to get things working. Clearing the SAs did not fix it.
cisco24x7 Wed, 04/02/2008 - 09:59
"We're running R62 (no hfa)"
There is NO HFA for R62 even if you want one.
"I am doing ssh to the Cisco ASA. Where does the output go?"
tye 'term mon' and you will see the debug output
"and the admin for that device had to reset the device
to get things working. Clearing the SAs did not fix it."
That is always an option if the other side agrees.
Good luck to you.
calterio Thu, 04/03/2008 - 15:16
Thanks for the replies and the info. Much appreciated!
So am I doing the right clear commands in the right sequence, to completely terminate the tunnel?
If not, what are the correct commands and sequence. Again, this is an ASA. Thanks!
