Desktop Administrator Threshold question
Apr 2nd, 2008
UCM 5.1.2
IPCC Express 4.5
I just implemented thresholds in Desktop Administrator. The agent sees when a call goes to caution and warning, but how does the Supervisor see this? Does the Sup have to be in the same Workflow group? What if Sup is over several groups? Where do they see it?
Jonathan Schulenberg Wed, 04/02/2008 - 09:47
Within CSD, there is a separate Supervisor Work Flow mechanism. They can set similar thresholds for the CSQs there. To my knowledge, you can't pre-configure this in CDA; supervisors must configure this individually.
spotlight41 Wed, 04/02/2008 - 10:09
I do not see a "Supervisor Work Flow" anywhere in CSD. Are you sure this is available in IPCC Express Premium 4.5, CSD 6.2(1)?
