ccm 6.0(1) cdr back up problem: empty folders
Apr 2nd, 2008
I am experiencing some problems. I perfom a back up using the Disaster Recovery Web.
I have tried backing up the CCM configuration and the CAR_CDR information and only the CAR_CDR database.
Tha process is succesfully completed, I get the 2008-04-02-13-43-45_CCMPUBLISHERNAME_cdr_car_cdrrep.tar in my SFTP server. In the log there are no errors.
But when I try to untar the backup file I get thousands of errors qith the following description:
! C:\bkp sla 2008.04.02\2008-04-02-13-43-45_CCMPUBLISHERNAME_cdr_car_cdrrep.tar: It can't be opened \var\log\active\cm\cdr_repository\preserve\20080401\cdr_StandAloneCluster_01_200804012227_14358 (var\log\active\cm\cdr_repository\car\20080401\cdr_StandAloneCluster_01_200804012227_14358 --> \var\log\active\cm\cdr_repository\preserve\20080401\cdr_StandAloneCluster_01_200804012227_14358)
! C:\bkp 2008.04.02\2008-04-02-13-43-45_CCMPUBLISHERNAME_cdr_car_cdrrep.tar: The symbolic link points to a non-existing file.
In the .tar file the 2008-04-02-13-43-45_CCMPUBLISHERNAME_cdr_car_cdrrep.tar\\var\log\active\cm\cdr_repository\car\dateName files are empty.
Why are these data missing?
The 2008-04-02-13-43-45_bio-ccmpub_cdr_car_cdrrep\common\drf\CDR_CAR\cardb.bin file is 200MB.
Thanks in advance for your help.
/Amaia
