How to configure CSD for testing?
Answered Question
Apr 2nd, 2008
Hi all,
I would like to implement Cisco Secure Desktop in our WebVPN setup, but I need a way to configure and test it without effecting our existing WebVPN users.
It seems to me that if I create a Windows Location with a criteria that *only* my test machine matches, all other users will fail. If I enable all features "when location matching fails," existing users won't see a difference.
Is this correct? Also, with this setup, will the VPN still attempt to push out the CSD software when users connect?
Any advice is appreciated.
- Steve
Correct Answer by irisrios about 8 years 10 months ago
Yes, Existing users won't see a difference "When Location matching fails" . This option "when location matching fails" helps Windows clients use the VPN to browse the web as a minimal connection option, if the client PC does not match any of the configured locations criteria.
Overall Rating: 5 (1 ratings)
Correct Answer
irisrios Tue, 04/08/2008 - 07:57
