CiscoWorks processes were not stopped even after the daemons were stopped
Apr 2nd, 2008
I am upgrading the Ciscoworks Common Services from 3.0.5 to latest which is 3.0.6
I am now running into issues that will not allow the successful installation of 3.0.6
Error:
process. You must stop all processes listed below to
proceed successfully with this installation.
Click Next to proceed with the installation.
Click Cancel to exit.
cd \Program Files\CSCOpx
cd \Program Files\CSCOpx\CSCOpx\MDC\Apache\Apache.exe
cd \Program Files\CSCOpx\CSCOpx\bin\cmf_crash_handler.dll
cd \Program Files\CSCOpx\CSCOpx\bin\libeay32.dll
cd \Program Files\CSCOpx\CSCOpx\bin\perl.dll
cd \Program Files\CSCOpx\CSCOpx\bin\ssleay32.dll
cd \Program Files\CSCOpx\CSCOpx\MDC\Apache\ApacheCore.dll
cd \Program Files\CSCOpx\CSCOpx\MDC\Apache\Win9xConHook.dll
cd \Program Files\CSCOpx\CSCOpx\MDC\Apache\modules\ApacheModulePerl.dll
cd \Program Files\CSCOpx\CSCOpx\MDC\Apache\modules\mod_jk.dll
cd \Program Files\CSCOpx\CSCOpx\objects\perl5\lib\MSWin32-x86\auto\Socket\Socket.dll
Looking at the fix in 3.0.6 docs i see it reference CSCsj05465 but it did not give me how to shut those processes manually.
(Only Cisco Staff have Access to CSCsj05465) Does anyone have a solution to upgrade successfully ?
sanyaolu Wed, 04/02/2008 - 09:57
I stopped Ciscoworks Web Services in Windows Services and it resolved it
Joe Clarke Wed, 04/02/2008 - 10:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This indicates that your services configuration may be incorrect. Most CiscoWorks services should be set to Manual startup in the Services control panel. The only services that can be Automatic are Daemon Management, syslog, RSH, TFTP, and the IPM services. If you have changed any of the service startup parameters for the other services, set them back to Manual, and reboot.
