CS MARS
Apr 2nd, 2008
How to add the non cisco security in CS MARS for example Nokia check point ,Proventia network-IPS,Trend micro ?
After adding it will be appear in CS MARS Security and monitor devices or noT
Overall Rating: 5 (1 ratings)
CSCO10320953 Tue, 04/08/2008 - 01:59
HI MHELLMAN/ALL,
Nokia check point model IP390 Package
Check Point CPinfo (Sun Feb 4 18:51:55 IST 2007 Build 911000041)
/opt/CPsuite-R65 Check Point VPN-1 Power/UTM NGX R65 (Tue May 29 09:10:38 IDT 2007 Build 620000436)
It will support CS MARS
mhellman Tue, 04/08/2008 - 04:52
  • Blue, 1500 points or more
Based on the table of supported devices, it should work.
