VG224 supported in UCM 6.0?
Apr 2nd, 2008
Trying to get a VG224 registered to UCM 6.0 but it is not registering. I noticed in the vg224 sccp setup, you can put a CCM version in there (but only up to 4.1). Is VG224 SCCP setup supported with UCM6.0?
I only need to fun analog phones off of this.
Overall Rating: 5 (2 ratings)
matthewpage Wed, 04/02/2008 - 10:56
Im almost 100% sure that VG224 isnt supported in call manager 6.0 only Vg248 is supported.
Matt
matthewpage Wed, 04/02/2008 - 12:29
fair enought but i was fairly certain that the 6608 module and the vg224 were no longer supported. I will try get some confirmation.
Are you running 12.4T image?
Rob Huffman Wed, 04/02/2008 - 12:34
Hi Daniel,
I have worked with people who are successfully using the VG224 with CCM 6.0 so I don't think that is the issue :)
Here is a post from Adam;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbfb6fb
I am not an expert with the VG224 as we are using all VG248's but there are some excellent config steps shown in this doc;
http://www.cisco.com/en/US/customer/docs/ios/12_4t/12_4t2/ht1vg224.html
Hope this helps!
Rob
PS: I think the VG248's (like we are using :( are being phased out in favour of the VG224's.
matthewpage Wed, 04/02/2008 - 12:53
my bad it must have been the vg200 i was thinking about. Sorry about that.
Matt
Rob Huffman Wed, 04/02/2008 - 14:05
Hey Matt,
Every time I turn around one of the products we use is going EOL :) Who knows from day to day (I think we need to get on the EOL Mailer).
Take care,
Rob
UCcomp2007 Thu, 04/03/2008 - 03:32
Thanks Rob and everyone for your replies. I could not get VG224 when I setup as SCCP, so I switched it to MGCP. It registered right away.
