CPEs same interface connection issues
Apr 2nd, 2008
Actually I have a Cisco 12008 GSR with GE Line Cards, a GE interface is connected to 2960G switch in mode Trunk which receives diferent Base Stations where Customers CPEs are connected. We have created sub-interfaces per every Base Station, the problem faces when two CPEs connected to the same sub-interface (of course on the same ip address range) can not ping each other or communicate using WAN interface, in some Cisco 2821 we solve this issue applying ip local-proxy-arp command on subinterface. Please if somebody knows a similar command on Cisco 12000 GSR or an alternative solution, I really appreciate your help.
Best Regards
Jackson
americatel Mon, 04/21/2008 - 07:19
Yes, but nothing indicates the reason for this behaviour, the "proxy-arp enable" command must solve that problem but even when its enabled on interfaces doesnt work.
GigabitEthernet4/0.2 is up, line protocol is up
Internet address is xxx.xxx.xxx.xxx/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP Null turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, Distributed, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
Thank you for your help
