MOH question
Answered Question
Apr 2nd, 2008
Is it possible for MOH to be played only for off-net calls instead of both off-net and on-net?
-Shikamaru
Correct Answer by mattcalderon about 8 years 11 months ago
Well you would still need to reference a MRGL in your device pool for conferencing, Xcode, MTP ect if you want to utilize those resources. you may just need to create a MRGL that excludes your MOH servers and add those to the gateway MRGLs only.
Correct Answer by Jaime Valencia about 8 years 11 months ago
restrict the access to internal users not to be able to reach the MOH server, only leave the MOH server available to the GWs.
javalenc
if this helps, please rate
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Wed, 04/02/2008 - 13:51
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
mattcalderon Wed, 04/02/2008 - 14:19
  • Silver, 250 points or more
Essentially would this be the same as taking the MOH server out of the MRGL for the phones?
shikamarunara Wed, 04/02/2008 - 15:25
javalenc,
It sound like your suggesting that the gateway be placed in a device pool that has access to the MRGL that references the MOH server. The divice pool that the phones are a part of would not reference one at all, correct?
-Shikamaru
Correct Answer
mattcalderon Wed, 04/02/2008 - 15:29
