Specific gateway when calling from a DN?
Apr 2nd, 2008
May be a noob question...
If a particular DN is assigned to a phone button, is there a way to make it such that any outbound calls from that DN go to a particular gateway?
Ed
Kenneth Mohammed Wed, 04/02/2008 - 12:40
  • Silver, 250 points or more
Yes. Make a route pattern and point to desired exiting gateway. Put route pattern in a partition. Put DN in the partition that you just created. When a call is made from the DN in question, it will go out of the gateway that you pointed the route pattern to. Hope that makes sense.
mrguitar Wed, 04/02/2008 - 12:49
Thanks for the info!
If the route pattern is already being used by a non-partition user, do I have to create a new, identical one, or can everyone continue to use the route pattern if I place it into a route partition?
Kenneth Mohammed Wed, 04/02/2008 - 12:52
If you place said route pattern into a partition, only the DN's in that partition will be able to use that route pattern. Therefore I would personally make an identical route pattern and put it in a partition.
mrguitar Wed, 04/02/2008 - 12:54
Great, thanks!
Will this new partition affect incoming calls at all, as well?
Ed
Kenneth Mohammed Wed, 04/02/2008 - 13:12
Just make sure that this partition is in the Calling Search Space of your gateway and you should be fine.
