04-02-2008 12:44 PM - edited 03-03-2019 09:23 PM
Hi guys any ideas what may be causing the following issues..
The call rings my phone, but after 2 rings it cuts off.
call path:a dialer originate the all:
dailer--->cisco2811--->FW--->internet-->voip gateway in UK--->telco in UK--->underlying carrier--->telco in US--->my phone (either desk or cell phone)
it appears that the UK gateway is sending user info/protocol that the US telco may not reconignized. I am using codec:g711ualaw, we also tried g729..
PS:local calls to UK work fine, it is just the US calls that do not work...
any ideas?
TX
Solved! Go to Solution.
04-03-2008 09:46 AM
His, this seems to be CSCsi94745, there are workarounds, however best solution is to upgrade to e.g. 12.4(11)XJ4, that also will give you the iLBC coded that is great for low bit rate over the internet.
04-02-2008 03:30 PM
On the voice gateway, take "debug isdn q931".
04-03-2008 05:28 AM
04-03-2008 07:51 AM
04-03-2008 09:46 AM
04-03-2008 11:56 AM
Thanks a lot, I will consider that, but you gave me a very good hint also, since I have my isdn switch type as:isdn switch-type primary-dms100, I changed it to :isdn switch-type primary-ni and it seems to be working fine so far, I have not gotten that same error yet, I will let it sit there for the rest of the day, I will definitely get it upgraded...I will let your know.
Any workarounds that you may think of in the meantime.
thx
