04-02-2008 12:49 PM - edited 03-05-2019 10:09 PM
hello
I need set up the max EM-HDA-6FXO, how many can to be installed in router 3825.
04-08-2008 10:33 AM
The Cisco High-Density Extension Module operates in any network module (NM) or enhanced network module (NME) slot on the Cisco 3825 and Cisco 3845 integrated services routers.
Two (2) , EVM-HD Modules Supported on Cisco 3825 router.
Also refer the following link :
04-08-2008 02:49 PM
Hello. thanks for reply. this is helpful.
07-02-2010 06:33 PM
For 3825 are suppoted 1 and for 3845 are supported 2 in slots NM o NME, Check table 3..
