Unity 5.0 Broadcast Messages and Public Distributions
Apr 2nd, 2008
We have a new Unity system. Before sending out a Broadcast message to the whole world, we would like to send one to a limited list so our administrators can understand how this works.
We understand that the MWI will not come on and like the feature of forcing a user to listen first.
The problem is that when try to send to a Publice Distribution list, it is not sent as a broadcast, but rather as a message which lights the lights and allows for notification, but also does not force the user to listen. This is different than the action I thought which is that I would limit the broadcast to the distribution list.
Any suggestions on this would be appreciated.
Rob Huffman Wed, 04/02/2008 - 15:31
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Gerald,
If you have a maintenance window when few users are on site you could send out the "test" Broadcast and then after seeing how it works use the Delete Broadcast Message feature before all users have to listen to it.
Unity Broadcast Message Manager
Sending a New Broadcast Message
From this link;
http://ciscounitytools.com/App_BroadcastMessageManager.htm
Just a thought,
Rob
ghorna229 Thu, 04/03/2008 - 05:13
Rob,
Thank you for the suggestion. I am just confused as to why I am given the option in broadcast manager to use a DL when it is not going to be a pointed Broadcast. It defeats the purpose in my opinion. What if I needed to send a broadcast that should not be skipped to a building that the others do not need to hear.
Just my thoughts.
