netsconfig job on LMS 3.0
Answered Question
Apr 2nd, 2008
I want to schedule a daily job to copy my config to a flash card.
on the router the command would be
copy run disk1:
the router would then ask if the name should be running-config ...
How can I do this with netconfig? as I have no way of sending a carriage-return (enter)
Correct Answer by Joe Clarke about 9 years 3 weeks ago
Netconfig does support interactive commands. You will need to use the command response sequence in your job. For example:
copy runn disk:
This assumes a dialog like:
copy runn disk1:
Destination filename [running-config]?
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]
For more on Netconfig and interactive commands, consult the RME online help:
http://SERVER/help/rme/fundamentals/netcfg_AdhocTasks.html
Of course, you could configure "file prompt quiet" on the device, and then just run "copy runn disk1:" without needing to answer any questions.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 04/02/2008 - 14:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
copy runn disk:
copy runn disk1:
srego4 Wed, 04/02/2008 - 14:54
thanks jclarke. I did not even finish filling up the TAC form... and got this answer.
and yes it worked fine.
Thanks again.
