UC520 key system setup doesn't show caller ID
Answered Question
Apr 2nd, 2008
What else do I need to do here to get caller ID to show on my phones? Right now, incoming calls show as from AO, A1 and so on?
Diego
voice-port 0/1/0
connection plar opx 3A10
caller-id enable
voice-port 0/1/1
connection plar opx 3A11
caller-id enable
dial-peer voice 50 pots
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 51 pots
destination-pattern A1
port 0/1/1
no sip-register
ephone-dn 30 dual-line
number 3A10 no-reg primary
label Line 1
call-forward busy 200
call-forward noan 200 timeout 10
trunk A0
ephone-dn 31 dual-line
number 3A11 no-reg primary
label Line 2
trunk A1
Correct Answer by smalkeric about 9 years 2 weeks ago
Have you verified if the pots line plugged into FXO port has callerID service enabled ? You should be able to check that by plugging that line directly into an analog phone that supports callerID Meanwhile,
you may choose to configure following commands under voice port to spoof this info:
voice-port x/y/z
station-id num 1234567890 <--change to whatever you want
station-id name From PSTN
shut
no shut
Overall Rating: 5 (1 ratings)
Correct Answer
smalkeric Tue, 04/08/2008 - 12:37
  • Silver, 250 points or more
voice-port x/y/z
shut
no shut
DIEGO ALONSO Wed, 04/09/2008 - 10:49
The num 1234567890 and name "From PSTN" do show for incoming calls. When those commands are not there only A0, A1, and so on show. Don't know what this tells me though?
DIEGO ALONSO Wed, 04/09/2008 - 11:49
Nevermind, I am an idiot. All our analog trunks have calledID EXCEPT the one trunk I used for testing!!!
Thank you for your help.
Diego
