1242AG Implementation Question
Apr 2nd, 2008
I was looking at using a 1242AG and getting 4 50ft cables and antennas to attach to the end of the cable and then deploying them clockwise alternating the frequency on each zone(2.4/5.8/2.4/5.8). I guess I am wanting this radio to cover 4 zones.Will this work or does polarity in the 2.4's work together to cover 1 zone and the 5.8's work together to cover 1 zone?
Scott Fella Wed, 04/02/2008 - 15:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You can't do that.... you can have the 2.4 on one zone and the 5GHz on the other, but the reason for two antennas is for diversity. If you only will use one, you set the antenna on the primary port and also have to set that on the AP. Depending on the type of cable, you will have db loss, so make sur eyou calculate that.
