Need help on Translation pattern
Apr 2nd, 2008
Dear Friends, I want to know why we use # symbal in the translation pattern. 3210.#9xxxxxxxxxx.
why we are using # in the translation pattern, some time # in the end of the translation pattern.
pls let me in details why we are using? what is the use of it.
Regardsa
Esa
pklos Thu, 04/03/2008 - 02:30
  • Silver, 250 points or more
Usually # is used as finishing/confirming sign for variable length call number. For example for international call you don't know how long number is, so you can do 0.00!#
you can put triple zeros, next as long number as needed and at the end press # to avoid waiting for inter digit timeout.
regards,
PK
esa786_2 Thu, 04/03/2008 - 14:41
Hi. If # is at the end, your answer is correct, if the # is in front like 3269.#2356421234 , here what is the use of # at front
Esa
