Exporting User Account details from ACS Solution Engine (SE) v4.1
Apr 2nd, 2008
The primary ACS SE has over 500 user accounts registered. Each account has a statically defined IP address. Is there a way to export all the user accounts including its associated account details?
From this export, I can then assess which IP addresses are allocated and even simply being able to determine what is the next IP address that can be allocated to a new user account. Other useful analysis can be applied to all this.
I'm currently running Release 4.1(4) Build 13 Patch 2
Jagdeep Gambhir Thu, 04/03/2008 - 06:04
  • Red, 2250 points or more
ACS backup files are not in a readable format, if you try to open, it will show all junk.
There is a software by Extraxi that has a feature you are looking for.
www.extraxi.com
You can download the free trial of that software.
~JG
Do rate helpful posts
