04-02-2008 06:17 PM - edited 03-15-2019 09:49 AM
Need your expert advice here. I am trying to connect quite a few 7960G phones to a non-cisco 802.3af compliance POE switch. The phone didn't power up I guess it's due to the fact it is a Cisco pre-standard POE phone. Is there any workaround to resolve this issue? Will the "Catalyst Inline Power Patch Panel" do any good for me? Please advise.
04-02-2008 06:34 PM
Hi Ted,
You are most correct :) Here is another (Cisco Partner) be sure to look at the secondary splitter required for the 7960 pre-standard PoE.
PowerDsine 6000 Power over Ethernet Midspan Family
http://www.powerdsine.com/Products/Midspan/PD_6000.asp
Hope this helps!
Rob
04-03-2008 02:05 PM
Hi Rob,
Thanks for the info. That was really helpful. And just want to make sure I am clear on this. If the access switch can supply 802.3af POE, I can just use the PD-PS-401/Cisco POE splitter, one RJ45 to the the POE switch, and the other RJ45 along with the AC plug to the 7960G phone?
Thanks for your help again. -Ted
04-03-2008 04:39 PM
Hi Ted,
Yes, this product will enable you to use the 7960 with your 802.3af switch. I don't beleive it needs AC either (the picture doesn't portray this well). I have not used this splitter so you may want to test one out first (they are pretty cheap (look on Google))
My understanding is that they work well :)
http://www.cisco-partners.info/showpdf.asp?f=3&p=72
Hope this helps!
Rob
