Unity express 2.1 to 2.3.4
Apr 2nd, 2008
I need to upgrade some Unity Express modules to 2.3.4 to fix the DST issue. In the documentation it does not state whether you need to upgrade the VM licenses.
1: Can the licenses for 2.1 be used for any version of 2.x?
2: How do you make sure there is no risk of corruption or loss of licenses during upgrade? The doc says the backup only saves config and recordings.
