CallerID problem from PSTN(FXO)
Answered Question
Apr 2nd, 2008
I have a very strange problem with callerID from my PSTN.
The lines from the PSTN is connected to a vic2-4fxo card with NM-HD-2VE.
I used MGCP for CCM.
PSTN has callerID enabled.
But the line is placed on the fxo, it does not display on the IP phones.
When I connected PSTN line to a analog phone, I get callerID displayed on the the analog phone.
Correct Answer by Jaime Valencia about 9 years 1 month ago
caller ID on FXO is not supported using MGCP, if you want called ID you need to switch to H323
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 04/02/2008 - 22:10
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
