Ip Phone dead?
Apr 3rd, 2008
Hi experts,
We just upgraded the firmware of our 7941s. All are good except one. It doesn't upgrade at all. I factory reset it by holding #, 123456789*0#.
After this, it's still not fixed. Then I directly connected it to a laptop as TFTP server with SEPxxxxxx.cnf, term41.defaults.loads, etc. with it.
However the phone is not responding at all. Then I factory reset it again the 2nd time. Now the speaker button & line button blink once, then it's dead. no power.
I also tried connecting a power supply but the same happens. the speaker button & line button blink once, then it's dead.
Can anyone help me how to troubleshoot it? Or the only thing I should do is forward it to TAC?
tnx
paolo bevilacqua Thu, 04/03/2008 - 10:35
  • Hall of Fame,
    Founding Member
Try the alternate reset sequence:
3491672580*#
After that, wait, it can take 10 minutes without display activity to revive the phone.
redrobish Thu, 04/03/2008 - 18:25
thanks p.bevilacqua
Tried it but no success!
any more idea?
tnx
paolo bevilacqua Fri, 04/04/2008 - 04:33
  • Hall of Fame,
    Founding Member
Do packet capture and you will see that either the phone is not give a valid dhcp reply with option 150, or it reuest some file that the tftp server doesn't give.
redrobish Sun, 04/20/2008 - 22:40
Hi Can anyone give me what should be on the SEP.CNF.XML & xmlDefault.CNF.XML. Seems i'm lacking something on it.
thanks
paolo bevilacqua Mon, 04/21/2008 - 03:24
  • Hall of Fame,
    Founding Member
What do you have, CM or CME ? check that the ephone is configured correctly in there.
redrobish Mon, 04/21/2008 - 14:42
CM with 7941G sccp phone.
firmware:SCCP41.8-3-4SR1S
tnx
0825784007 Mon, 06/02/2008 - 08:15
How about description of how the problem was solved, then at least these postings are usefull.
orangejoffe Fri, 06/19/2009 - 06:49
Hello, I'm facing the same problem. Could you please share with me what was done to fix the issue? Thank you.
redrobish Mon, 06/22/2009 - 00:01
The only thing that I've done is set a specific pc as a TFTP server, then I copied all the phone's files from my CM for that particular model. Then when all was set, i reset it as advised then it works!
hth
