how to display the most aggressive route version number ?
Apr 3rd, 2008
if a router has more than 10,000 routes,some of them are flapping,others not,how do i display the most aggressive route by the route version number?
thanks
nambi_gct Thu, 04/03/2008 - 02:26
  • Bronze, 100 points or more
If it is BGP you can consider using dampening.Based on the suppressed route ifo you can fins out the problematic route.Otherwise you can use RMON to set an upper threshold and can see when it is being crossed.
