IPSEC b/w ASA and Router --- with nat stuff
Apr 3rd, 2008
I need help regarding the following issue..
An asa is connected to a router which is connected to the internet.
A vpn must be established b/w ASA and a router that is over internet . The ASA is not directly connected to the internet. It is connected to a router which nat the Asa outside ip to a static global IP .
All i need to know is that do need any special configs for this . or its the same as if ASA would have been directly connected to the internet
smalkeric Wed, 04/09/2008 - 07:30
In order to configure a LAN-to-LAN tunnel between a Cisco IOS? router and an Adaptive Security Appliance (ASA), these configurations are required on the ASA:
Configure the crypto ipsec command in Phase 2.
Configure the isakmp policy command.
Configure the nat 0 command and the access-list command in order to bypass NATting.
Configure the crypto-map command.
Configure the tunnel-group DefaultL2LGroup command with group information
